Giriş
When your Logitech Spotlight is not charging, the battery might be the problem.
Neye ihtiyacın var
Remove the back plate.
Be careful not to break the plastic latch indicated in the image and watch out for glue.
Undo the screws near the top of the case. Then carefully slide the internal plastic case upward to remove it.
On the board underneath, remove 3 screws.
Watch out for the plastic latch.
Carefully remove the board to gain access to the battery.
Remove and replace the battery.
Once reassembled, the device should be working again.
To reassemble your device, follow the steps in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
10Kılavuz Yorumları
I dont't think this is an easy iFixit instruction. It's rather mid or hard especially since you have to break plastic parts to even access the screws. It might make sense to change the difficulty on this one :D @mariaparker
@fixnils you are completely right, that was a mistake on my part! Thanks for noticing :)
@mariaparker could we maybe add the specifications of the Lithium battery to the repair manual?
I could provide an image from my logitech spotlight to help with that.
Users are coming back again and again to ask the same question about the battery specification and the battery size.
At step 1, I was able to twist and push a strong but thin screwdriver (Philips 000) through the plastic parts which would otherwise block access to the screws. By angling the screwdriver slightly the screws can be released without breaking the plastic completely, so you still have the retention of the usb dongle - although obviously this isn't essential.
If you have to heat-shrink connection of the original plug and new battery wires they may be too bulky for the board to go back properly in the carrier. I had to cut away small bits of ribs on the carrier
Thanks for the useful instructions
Stephen
