Ana içeriğe geç
Logitech Spotlight Battery Replacement
Neye ihtiyacın var
  1. Logitech Spotlight Battery Replacement, Removing the back cover: adım 1, 2 resimden 1. Logitech Spotlight Battery Replacement, Removing the back cover: adım 1, 2 resimden 2.
    • Removing the back cover :
    • The back cover is gluded on back middle and lower side. So it's much easier to rub in from top edge.
  2. Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: adım 2, 3 resimden 1. Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: adım 2, 3 resimden 2. Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: adım 2, 3 resimden 3.
    • Try to tick out the wire of the battery to get more space.
    • Cut out the yellow tape of battery.
    • Desoldering the two wires connecting the battery to the board. Carefully don't touch the the positive and negative terminals on the same time for security.
  3. Logitech Spotlight Battery Replacement, Pull out the battery: adım 3, 1 resimden 1.
    • Use pliers to clamp the board on the battery and pull the battery out. The battery is glued on the mainboard, and the battery is too long for back hole. So it's no easy to pull out.
  4. Logitech Spotlight Battery Replacement, Solder the new battery: adım 4, 2 resimden 1. Logitech Spotlight Battery Replacement, Solder the new battery: adım 4, 2 resimden 2.
    • The original battery size is 3.9mm x 8mm x 36 mm. For ease of installation, I get a smaller battery with size 3.5mm x 8mm x 29 mm.
    • Put the new battery into the battery hole, and solder the new battery wires with the original wires. And use polyimide tape to cover the wiring point for safety .
  5. Logitech Spotlight Battery Replacement, Cover back the back cover: adım 5, 1 resimden 1.
    • Clear out the original clue on the two sides and put some clue on. Then Cover back the back cover.
Sonuç
Leo Hsi
121 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Potresti indicare tipo di batteria e dove comprarla? grazie
Sandro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 522
