Ana içeriğe geç
Logitech UE Boom 3 Battery Replacement
Neye ihtiyacın var
  1. Logitech UE Boom 3 Battery Replacement, Base: adım 1, 2 resimden 1. Logitech UE Boom 3 Battery Replacement, Base: adım 1, 2 resimden 2.
    • Flip the speaker so the base is facing upwards.
    • Place the iFixit opening picks in the gaps of the speaker.
    • Use the picks to pry open the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Boom 3 Battery Replacement: adım 2, 2 resimden 1. Logitech UE Boom 3 Battery Replacement: adım 2, 2 resimden 2.
    • Use a Jimmy to completely pry the base away from the rest of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Boom 3 Battery Replacement, Battery: adım 3, 3 resimden 1. Logitech UE Boom 3 Battery Replacement, Battery: adım 3, 3 resimden 2. Logitech UE Boom 3 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove the adhesive strap holding the battery in place.
    • It is sticky and tightly bounded, but removal is necessary.
    • Pull out the battery by hand until it is out of the casing and being held by the cable only.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Boom 3 Battery Replacement: adım 4, 2 resimden 1. Logitech UE Boom 3 Battery Replacement: adım 4, 2 resimden 2.
    • The battery will still be attached to motherboard via cable.
    • Carefully press down on the lever on the end of the cable and disconnect it from the motherboard.
    • This cable is intricate and is susceptible to damage beyond repair. Be extra careful to precisely insert and remove the cable as bending the pins can result in damage.
    • Remove the battery from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Donahue
603 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Konn Spring 2024 UMass Dartmouth, Team 1-4, Konn Spring 2024 üyesi
UMASSD-KONN-S24S1G4
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 59
Son 30 gün: 262
Her zaman: 5,345
