Ana içeriğe geç
Logitech UE Boom Motherboard Replacement
Neye ihtiyacın var
  1. Logitech UE Boom Motherboard Replacement, D-ring: adım 1, 1 resimden 1.
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Boom Motherboard Replacement: adım 2, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Boom Motherboard Replacement, Bluetooth Adapter: adım 3, 1 resimden 1.
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Boom Motherboard Replacement: adım 4, 3 resimden 1. Logitech UE Boom Motherboard Replacement: adım 4, 3 resimden 2. Logitech UE Boom Motherboard Replacement: adım 4, 3 resimden 3.
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech UE Boom Motherboard Replacement: adım 5, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 5, 2 resimden 2.
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech UE Boom Motherboard Replacement: adım 6, 3 resimden 1. Logitech UE Boom Motherboard Replacement: adım 6, 3 resimden 2. Logitech UE Boom Motherboard Replacement: adım 6, 3 resimden 3.
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech UE Boom Motherboard Replacement: adım 7, 1 resimden 1.
    • With the switch plate disconnected, remove it and your device should now look like this.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech UE Boom Motherboard Replacement, Lithium Battery: adım 8, 1 resimden 1.
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech UE Boom Motherboard Replacement: adım 9, 1 resimden 1.
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech UE Boom Motherboard Replacement: adım 10, 3 resimden 1. Logitech UE Boom Motherboard Replacement: adım 10, 3 resimden 2. Logitech UE Boom Motherboard Replacement: adım 10, 3 resimden 3.
    • Peel off the sleeve.
    FixBot'a Sor
    Yorum Ekle
  11. Logitech UE Boom Motherboard Replacement: adım 11, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 11, 2 resimden 2.
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
    FixBot'a Sor
    Yorum Ekle
  12. Logitech UE Boom Motherboard Replacement: adım 12, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 12, 2 resimden 2.
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
    FixBot'a Sor
    Yorum Ekle
  13. Logitech UE Boom Motherboard Replacement: adım 13, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 13, 2 resimden 2.
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
    FixBot'a Sor
    Yorum Ekle
  14. Logitech UE Boom Motherboard Replacement: adım 14, 1 resimden 1.
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
    FixBot'a Sor
    Yorum Ekle
  15. Logitech UE Boom Motherboard Replacement: adım 15, 1 resimden 1.
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
    FixBot'a Sor
    Yorum Ekle
  16. Logitech UE Boom Motherboard Replacement: adım 16, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove the battery by pulling it from the terminal as marked in the picture.
    FixBot'a Sor
    Yorum Ekle
  17. Logitech UE Boom Motherboard Replacement, Motherboard: adım 17, 2 resimden 1. Logitech UE Boom Motherboard Replacement, Motherboard: adım 17, 2 resimden 2.
    • Remove the speaker by pulling it from the terminal as marked in the picture.
    FixBot'a Sor
    Yorum Ekle
  18. Logitech UE Boom Motherboard Replacement: adım 18, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 18, 2 resimden 2.
    • Remove the second speaker by pulling it from the terminal as marked in the picture.
    FixBot'a Sor
    Yorum Ekle
  19. Logitech UE Boom Motherboard Replacement: adım 19, 2 resimden 1. Logitech UE Boom Motherboard Replacement: adım 19, 2 resimden 2.
    • Finally, remove the motherboard completely by pulling it from the terminal as marked in the picture.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sean Reilly
1.772 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 üyesi
CPSU-MANESS-F15S4G1
4 Üyeler
22 adet Kılavuz yazıldı
2Kılavuz Yorumları
Is there anywhere I can buy the motherboard to replace my UE Boom board fried by lightning?
Mohd Razali Hamid - Yanıt Paylaş
I would like to know where can I buy the UE BOOM Mother Board.
許志豪 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 78
Her zaman: 11,122
