Ana içeriğe geç
Logitech UE Boombox Battery Replacement
Neye ihtiyacın var
  1. Logitech UE Boombox Battery Replacement, Lithium Battery: adım 1, 2 resimden 1. Logitech UE Boombox Battery Replacement, Lithium Battery: adım 1, 2 resimden 2.
    • Place the Boombox on the side with its bottom facing you.
    • Remove one 8 mm Phillips #2 screw.
  2. Logitech UE Boombox Battery Replacement: adım 2, 1 resimden 1.
    • Pry off the rubber battery cover using a metal spudger.
  3. Logitech UE Boombox Battery Replacement: adım 3, 2 resimden 1. Logitech UE Boombox Battery Replacement: adım 3, 2 resimden 2.
    • Expose the battery by gently pulling it away from the battery cavity.
  4. Logitech UE Boombox Battery Replacement: adım 4, 3 resimden 1. Logitech UE Boombox Battery Replacement: adım 4, 3 resimden 2. Logitech UE Boombox Battery Replacement: adım 4, 3 resimden 3.
    • Firmly press down on the end of the latch and pull connector apart.
    I’d like to know what is the other connector? Is it possible to upgrade the battery to two cells?
    Max_Power - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Breean Mokede
282 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-1, Bruce Fall 2016 CSU Fullerton, Team 1-1, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S1G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where can I purchase this replacement battery and a power adapter for this exact model of speaker
phonse4u - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 2,255
