Ana içeriğe geç
Giriş
This guide will walk you through the procedure of removing the speaker grille.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a metal spudger to pry open the power button cover. Once the power button cover is slightly opened, use your fingers to remove the power button cover.
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Press firmly  on the end of the latch and pull the two-wire connector away from the base to separate. Press firmly  on the end of the latch and pull the two-wire connector away from the base to separate. Press firmly  on the end of the latch and pull the two-wire connector away from the base to separate.
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Firmly press on the end of the latch and pull the four-wire connector away from the base to separate. Firmly press on the end of the latch and pull the four-wire connector away from the base to separate. Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Lightly, pry up on each side of the black band connector lock using your fingertips. Once unlocked, pull straight up on the connector to remove. Once unlocked, pull straight up on the connector to remove.
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Remove the five black 14mm Phillips #2 screws from the black plastic side panel. Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. On the opposite side of the device, pry open the volume rocker with a metal spudger. Remove the panel with your fingers once the volume rocker is slightly opened.
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Remove the five black 14mm Phillips #2 screws from the black plastic side panel. Remove the one silver16 mm Phillips #2 screw from the black plastic side panel. Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Firmly press on the end of the latch and pull the two-wire connector away from the base. Firmly press on the end of the latch and pull the two-wire connector away from the base.
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Pull up on the aluminum boombox handle to remove. Pull up on the aluminum boombox handle to remove.
    • Pull up on the aluminum boombox handle to remove.
  10. Use a metal spudger to pry the rubber base apart from the aluminum grille. Use a metal spudger to pry the rubber base apart from the aluminum grille.
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Pull the rubber base away from the boombox. Pull the rubber base away from the boombox.
    • Pull the rubber base away from the boombox.
  12. Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Pull vertically on the speaker grille to remove it from the boombox. Pull vertically on the speaker grille to remove it from the boombox. Pull vertically on the speaker grille to remove it from the boombox.
    • Pull vertically on the speaker grille to remove it from the boombox.
Sonuç
Bir başkası bu kılavuzu tamamladı.
tyler hua
253 İtibar
1 Kılavuz yazıldı
Takım
CSU Fullerton, Team 1-1, Bruce Fall 2016 CSU Fullerton, Team 1-1, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S1G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Awesome guide thanks. Had to strip mine down as it stopped working, replugged it all and it’s good as new. Knowing how it’s down saves brute force and ignorance :)
matt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 666
