Ana içeriğe geç
Logitech UE Hyperboom Battery Replacement
Neye ihtiyacın var
  1. Logitech UE Hyperboom Battery Replacement, Handle: adım 1, 2 resimden 1. Logitech UE Hyperboom Battery Replacement, Handle: adım 1, 2 resimden 2.
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Hyperboom Battery Replacement, Top Panel: adım 2, 2 resimden 1. Logitech UE Hyperboom Battery Replacement, Top Panel: adım 2, 2 resimden 2.
    • Use your hands to carefully pry the plastic cover off of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Hyperboom Battery Replacement: adım 3, 3 resimden 1. Logitech UE Hyperboom Battery Replacement: adım 3, 3 resimden 2. Logitech UE Hyperboom Battery Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
    • Remove the top panel to access the internal components.
    • Use a metal spudger to completely disconnect the top panel.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Hyperboom Battery Replacement, Battery: adım 4, 3 resimden 1. Logitech UE Hyperboom Battery Replacement, Battery: adım 4, 3 resimden 2. Logitech UE Hyperboom Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Unplug the battery cord from the motherboard.
    • Remove the battery from the battery compartment.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ethan Abbott
859 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 80
Her zaman: 171
