Ana içeriğe geç
Logitech UE Hyperboom Bottom Panel Replacement
Neye ihtiyacın var
  1. Logitech UE Hyperboom Bottom Panel Replacement, Handle: adım 1, 2 resimden 1. Logitech UE Hyperboom Bottom Panel Replacement, Handle: adım 1, 2 resimden 2.
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    FixBot'a Sor
  2. Logitech UE Hyperboom Bottom Panel Replacement, Bottom Panel: adım 2, 2 resimden 1. Logitech UE Hyperboom Bottom Panel Replacement, Bottom Panel: adım 2, 2 resimden 2.
    • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
    FixBot'a Sor
  3. Logitech UE Hyperboom Bottom Panel Replacement: adım 3, 3 resimden 1. Logitech UE Hyperboom Bottom Panel Replacement: adım 3, 3 resimden 2. Logitech UE Hyperboom Bottom Panel Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
    • Pull the panel off to access the internal components.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Abbott
859 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 16
Her zaman: 39
