Ana içeriğe geç
Logitech UE Hyperboom DC Power Socket Replacement
Neye ihtiyacın var
  1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: adım 1, 2 resimden 1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: adım 1, 2 resimden 2.
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: adım 2, 2 resimden 1. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: adım 2, 2 resimden 2.
    • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Hyperboom DC Power Socket Replacement: adım 3, 3 resimden 1. Logitech UE Hyperboom DC Power Socket Replacement: adım 3, 3 resimden 2. Logitech UE Hyperboom DC Power Socket Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
    • Pull the panel off to access the internal components.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: adım 4, 3 resimden 1. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: adım 4, 3 resimden 2. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: adım 4, 3 resimden 3.
    • Unscrew the top 11.7m screw on the DC Power Socket panel using the Phillips #0 screwdriver.
    • Use the Jimmy to pry the panel away from the speaker, then disconnect the power cables from the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech UE Hyperboom DC Power Socket Replacement: adım 5, 2 resimden 1. Logitech UE Hyperboom DC Power Socket Replacement: adım 5, 2 resimden 2.
    • Remove the four 7.9mm screws from the daughterboard with the Phillips #0 screwdriver.
    • Pull the circuit board away from the panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Abbott
859 İtibar
8 adet Kılavuz yazıldı
1Rehber Yorum
G'day I've got the 2024 version that has a broken charging port and can't find a PCB replacement anywhere I'm in New Zealand probably why but do you guys reckon I could just swap it out with the older version of the charging board since there available.
Ethan Donaldson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 44
Her zaman: 150
