Ana içeriğe geç
Logitech UE Hyperboom Motherboard Replacement
Neye ihtiyacın var
  1. Logitech UE Hyperboom Motherboard Replacement, Handle: adım 1, 2 resimden 1. Logitech UE Hyperboom Motherboard Replacement, Handle: adım 1, 2 resimden 2.
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Hyperboom Motherboard Replacement, Top Panel: adım 2, 2 resimden 1. Logitech UE Hyperboom Motherboard Replacement, Top Panel: adım 2, 2 resimden 2.
    • Use your hands to carefully pry the plastic cover off of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Hyperboom Motherboard Replacement: adım 3, 3 resimden 1. Logitech UE Hyperboom Motherboard Replacement: adım 3, 3 resimden 2. Logitech UE Hyperboom Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
    • Remove the top panel to access the internal components.
    • Use a metal spudger to completely disconnect the top panel.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: adım 4, 2 resimden 1. Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: adım 4, 2 resimden 2.
    • Use the Jimmy to pry the fiber mesh cover away from the speaker.
    • Take the fiber mesh off of the speaker completely.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech UE Hyperboom Motherboard Replacement: adım 5, 3 resimden 1. Logitech UE Hyperboom Motherboard Replacement: adım 5, 3 resimden 2. Logitech UE Hyperboom Motherboard Replacement: adım 5, 3 resimden 3.
    • Use the Phillips #0 screwdriver to unscrew the three 9.2mm screws around the tweeter speaker.
    • Use the Phillips #0 screwdriver to unscrew the eight 10.1mm screws around the speaker driver.
    • Use a metal spudger to pry the tweeter speaker out of the socket.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech UE Hyperboom Motherboard Replacement: adım 6, 3 resimden 1. Logitech UE Hyperboom Motherboard Replacement: adım 6, 3 resimden 2. Logitech UE Hyperboom Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a metal spudger to break the adhesive seal around the speaker driver.
    • Use your hands to push the speaker driver out of its socket.
    • A lot of force will be necessary, so it is possible the power and ground cables might disconnect from the force of dislodging the speaker driver.
    • Disconnect the power and ground cables from both the speaker driver and tweeter.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech UE Hyperboom Motherboard Replacement: adım 7, 1 resimden 1.
    • Turn the speaker over, and face the two other speaker driver towards you.
    • Use the Phillips #0 screwdriver to remove the three 9.2mm screws around the speaker tweeter.
    • Use the Phillips #0 screwdriver to remove the eight 10.1mm screws around the speaker driver.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech UE Hyperboom Motherboard Replacement: adım 8, 2 resimden 1. Logitech UE Hyperboom Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a metal spudger to break the adhesive between the tweeter and the casing.
    • Disconnect the power and ground cables from the tweeter speaker to remove it completely.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech UE Hyperboom Motherboard Replacement: adım 9, 3 resimden 1. Logitech UE Hyperboom Motherboard Replacement: adım 9, 3 resimden 2. Logitech UE Hyperboom Motherboard Replacement: adım 9, 3 resimden 3.
    • Use your hands to remove the speaker driver from its socket.
    • Disconnect the power and ground cables to remove it completely.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech UE Hyperboom Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Logitech UE Hyperboom Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
    • Disconnect all of the cables connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Logitech UE Hyperboom Motherboard Replacement: adım 11, 3 resimden 1. Logitech UE Hyperboom Motherboard Replacement: adım 11, 3 resimden 2. Logitech UE Hyperboom Motherboard Replacement: adım 11, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the four supporting 7.9mm screws.
    • Slide the motherboard out of the top of the speaker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ethan Abbott
859 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 54
Her zaman: 119
