Ana içeriğe geç
Logitech UE MegaBoom 3 Battery Replacement
Neye ihtiyacın var
  1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: adım 1, 2 resimden 1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: adım 1, 2 resimden 2.
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE MegaBoom 3 Battery Replacement: adım 2, 3 resimden 1. Logitech UE MegaBoom 3 Battery Replacement: adım 2, 3 resimden 2. Logitech UE MegaBoom 3 Battery Replacement: adım 2, 3 resimden 3.
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE MegaBoom 3 Battery Replacement, Battery: adım 3, 3 resimden 1. Logitech UE MegaBoom 3 Battery Replacement, Battery: adım 3, 3 resimden 2. Logitech UE MegaBoom 3 Battery Replacement, Battery: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the lithium-ion battery from the inside of the speaker by gripping the battery using the plyers.
    • Here, it is ideal to use a tweezers as opposed to the plyers, however, the plyers makes it so much easier to take out the battery.
    • The battery should slide out as you pull against it with the plyers.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jason Doland
124 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 237
Her zaman: 4,013
