Ana içeriğe geç
Logitech UE MegaBoom 3 Speaker Driver Replacement
Neye ihtiyacın var
  1. Logitech UE MegaBoom 3 Speaker Driver Replacement, General Disassembly: adım 1, 2 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement, General Disassembly: adım 1, 2 resimden 2.
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 2, 3 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 2, 3 resimden 2. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 2, 3 resimden 3.
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Speaker Driver Replacement, Power Button Control Board: adım 3, 3 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement, Power Button Control Board: adım 3, 3 resimden 2. Logitech UE MegaBoom 3 Speaker Driver Replacement, Power Button Control Board: adım 3, 3 resimden 3.
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 4, 3 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 4, 3 resimden 2. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 4, 3 resimden 3.
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 5, 3 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 5, 3 resimden 2. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 5, 3 resimden 3.
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
  6. Logitech UE MegaBoom 3 Speaker Driver Replacement, Speaker Driver: adım 6, 2 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement, Speaker Driver: adım 6, 2 resimden 2.
    • Take of the metal rods by gently prying them out using the metal spudger.
    • Be sure to slide them out as gently as possible to prevent the rods from becoming damaged.
  7. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 7, 2 resimden 1. Logitech UE MegaBoom 3 Speaker Driver Replacement: adım 7, 2 resimden 2.
    • Once the rods are removed, you can pry it off and disconnect the speaker driver.
    • Repeat the same steps to disconnect the speaker driver on the other side of the speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Miles
981 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 71
Her zaman: 338
