Giriş
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom Auxiliary and USB Ports.
Neye ihtiyacın var
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Apply an upward force with your thumbs to loosen the end cap.
Grasp the end cap and lift up to seperate it from the base.
3 farklı kişi bu kılavuzu tamamladı.
10 Yorum
How can I purchase this part being replaced thanks
I also need this part due to water damage. Where Do I order this entire motherboard at?
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
