Ana içeriğe geç
Logitech UE MegaBoom Outer Mesh Replacement
Neye ihtiyacın var
  1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: adım 1, 3 resimden 1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: adım 1, 3 resimden 2. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: adım 1, 3 resimden 3.
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Outer Mesh Replacement: adım 2, 3 resimden 1. Logitech UE MegaBoom Outer Mesh Replacement: adım 2, 3 resimden 2. Logitech UE MegaBoom Outer Mesh Replacement: adım 2, 3 resimden 3.
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Outer Mesh Replacement: adım 3, 2 resimden 1. Logitech UE MegaBoom Outer Mesh Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Oscar Ambriz
958 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S9G2
4 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
You know where to buy a replacement mesh in custom colors
Jonathan Lang - Yanıt
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 3,841
