Ana içeriğe geç
Logitech Webcam Pro 9000 Front and Back Cover Replacement
Neye ihtiyacın var
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: adım 1, 2 resimden 1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: adım 2, 2 resimden 1. Logitech Webcam Pro 9000 Front and Back Cover Replacement: adım 2, 2 resimden 2.
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Sonuç
Timothy Forrest
19 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G34
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,233
