Giriş
There are two parts to the microphone: the cover and the microphone and its casing. It takes about the same amount of time to remove the cover and the microphone.
Neye ihtiyacın var
Grasp the white wire connector between the tabs and the socket.
Wiggle the connector back and forth to remove the front cover from the motherboard.
Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
Use the wedge to separate the two pieces.
2 farklı kişi bu kılavuzu tamamladı.
