Ana içeriğe geç
Logitech Webcam Pro 9000 Snapshot Button Replacement
Neye ihtiyacın var
  1. Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: adım 1, 2 resimden 1. Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Snapshot Button Replacement: adım 2, 2 resimden 1. Logitech Webcam Pro 9000 Snapshot Button Replacement: adım 2, 2 resimden 2.
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: adım 3, 3 resimden 1. Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: adım 3, 3 resimden 2. Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: adım 3, 3 resimden 3.
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Davis
236 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G34
4 Üyeler
16 adet Kılavuz yazıldı
3Kılavuz Yorumları
Power button? Does this actually turn the camera on and off? When I push it, it seems to just pause the screen for a moment. I thought maybe it was taking still shots, but I cant seem to find a folder with any in it. I've checked all Logitech's default folder directories. (Trying to figure out what this button does, or can actually be used for.) If you want to turn a webcam off, you usually just unplug them.
Edit: Manual says its a snapshot button, but I'd love for this to start/stop OR pause recording. Hm.....
Harrison - Yanıt
I've tried to properly update this to make it more accurate, but I'm unsure how the process works. Maybe I submitted it for review? I'm not sure, but my changes have not taken effect, yet.
Harrison - Yanıt
They were indeed submitted for approval, and have been approved! =)
Sam Goldheart -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 2,329
