Ana içeriğe geç
Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement
Neye ihtiyacın var
  1. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: adım 1, 3 resimden 1. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: adım 1, 3 resimden 2. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: adım 1, 3 resimden 3.
    • Obtain (4) 1000uF capacitors rated for 25 volts. The replacement capacitors featured in this guide were purchased from Digi-key. Digi-key part number: UHE1E102MHD6. http://search.digikey.com/scripts/DkSear...
    • Additional suggested tools for this repair are pictured.
  2. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 2, 1 resimden 1.
    • Caution: Be mindful of the dangerous high voltage that exist in this device when powered and for a short time afterward.
    • Place the camera upside down.
    • Using a small flat tool, pry off the plastic covers on each side of the case (outlined in orange)
  3. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 3, 1 resimden 1.
    • Removal of the covers reveal six philips head screws (green highlight).
    • Unscrew all six screws.
  4. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 4, 2 resimden 1. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 4, 2 resimden 2.
    • Flip the camera so the top is right-side up.
    • Remove the top of the case.
    • Notice the four damaged capacitors C26, C27, C31 and C32 (red highlight).
  5. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 5, 1 resimden 1.
    • Unscrew all four phillips head screws in each corner (green highlight).
    • Disconnect power cable (yellow highlight).
    • Lift and remove the clear front plastic lens cover.
    • Lift the circuit board and camera assebly out of the case.
    • Carefully separate the LED assembly from the four small connectors (highlighted in blue). Note: This step is not required for this repair. However, it reduces the possibility of inadvertent damage during the process.
  6. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 6, 3 resimden 1. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 6, 3 resimden 2. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 6, 3 resimden 3.
    • Desolder and remove the four capacitors (red highlight).
    • Suggestion: Mark the capacitors on top and on the bottom of the board to avoid damaging another component.
  7. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 7, 1 resimden 1.
    • Clean and remove remaining solder or debris from the area.
    • Cut leads on new capacitors to fit.
    • Solder the four new capacitors in place.
    • Notice: Pay attention to the polarity of the capacitors.
    • Insulate the leads and gently bend the capacitors to fit.
  8. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: adım 8, 1 resimden 1.
    • Suggestion: Before full reassembly, reattach the LED module, place the board and camera module into the case and reconnect the A/C cable to ensure proper operation.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I did the repair worked for 5 min's then starts acting up. Before the fix wouldn't work at all. Is there anymore suggestions?
martin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 43
Her zaman: 9,651
