Ana içeriğe geç
Logitech Z4 Desk Speaker Disassembly
Neye ihtiyacın var
  1. Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: adım 1, 3 resimden 1. Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: adım 1, 3 resimden 2. Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: adım 1, 3 resimden 3.
    • Use a PH2 screwdriver to remove the two screws on the back of the speaker.
    • the speaker has a cinch connector to plug in to the sub-woofer.
  2. Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: adım 2, 2 resimden 1. Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: adım 2, 2 resimden 2.
    • removing the decorative front panel with a plastic pick (guitar picks work great). it is quite sturdy but the adhesive film on the back of it is strong, so go slow or heat it up with a hairdryer.
  3. Logitech Z4 Desk Speaker Disassembly, Removing the housing screws: adım 3, 1 resimden 1.
    • removing the main screws for the speaker housing. using the same driver (PH2) we can remove the 8 screws holding the main speaker assembly together.
  4. Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: adım 4, 2 resimden 1. Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: adım 4, 2 resimden 2.
    • opening the speaker housing by prying it up evenly on all sides with the plastic pick.
    • it can be tapped lightly on the desk to make it fall out at the end of the process.
  5. Logitech Z4 Desk Speaker Disassembly, Taking inventory: adım 5, 3 resimden 1. Logitech Z4 Desk Speaker Disassembly, Taking inventory: adım 5, 3 resimden 2. Logitech Z4 Desk Speaker Disassembly, Taking inventory: adım 5, 3 resimden 3.
    • after opening the speaker fully you can see that the top and bottom membranes are not speakers, only decoration.
    • the middle one is connected with two wires matching the cinch connector on the cable.
    • the cable has a screw and some hot glue acting as a strain release for the cable.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
kugelzucker
315 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 2,947
