Ana içeriğe geç
Longboard Bearing Replacement Guide
Neye ihtiyacın var
  1. Longboard Bearing Replacement Guide, Longboard Bearings: adım 1, 3 resimden 1. Longboard Bearing Replacement Guide, Longboard Bearings: adım 1, 3 resimden 2. Longboard Bearing Replacement Guide, Longboard Bearings: adım 1, 3 resimden 3.
    • On a flat surface, unscrew the nut that holds the wheel on the axle using the correct size from the skateboard tool (1/2" size, typically the smaller of the 2 on the top of the 'T') and turning to the left.
  2. Longboard Bearing Replacement Guide: adım 2, 1 resimden 1.
    • Remove the wheel and the outside spacer from the board.
    • The spacer is the tiny circle between the axle and the wheel that keeps them from rubbing/grinding.
  3. Longboard Bearing Replacement Guide: adım 3, 3 resimden 1. Longboard Bearing Replacement Guide: adım 3, 3 resimden 2. Longboard Bearing Replacement Guide: adım 3, 3 resimden 3.
    • Use the pointy end of the small tool that comes with the Skate Tool and insert it under the bearing (look at the red arrow) to pry (and we mean PRY) out one of the bearings.
    • We recommend starting with the bearing on side of the wheel that stays closest to the board and prying in the direction of the green arrow.
  4. Longboard Bearing Replacement Guide: adım 4, 3 resimden 1. Longboard Bearing Replacement Guide: adım 4, 3 resimden 2. Longboard Bearing Replacement Guide: adım 4, 3 resimden 3.
    • Remove the spacer that sits between the bearings on the inside of the wheel.
    • Pry out the other bearing.
    • We used our fingers. The tool can also be used, whichever you find easier. We recommend pushing it out from the inside.
    • The last picture is all the parts that you should have at this point.
  5. Longboard Bearing Replacement Guide: adım 5, 3 resimden 1. Longboard Bearing Replacement Guide: adım 5, 3 resimden 2. Longboard Bearing Replacement Guide: adım 5, 3 resimden 3.
    • Insert one of the new bearings into the wheel. It should not matter what way you put it in unless they are specialty bearings.
    • Use your fingers to push it in, the tool can also be used, whichever you find easier.
    • Push until it stops against the built in stopper within the wheel.
  6. Longboard Bearing Replacement Guide: adım 6, 3 resimden 1. Longboard Bearing Replacement Guide: adım 6, 3 resimden 2. Longboard Bearing Replacement Guide: adım 6, 3 resimden 3.
    • Place in the spacer that goes between the bearings on the inside.
    • Make sure the spacer is standing upright (shown in the second picture).
    • Repeat step 5 to insert the other bearing on the other side of the wheel.
  7. Longboard Bearing Replacement Guide: adım 7, 3 resimden 1. Longboard Bearing Replacement Guide: adım 7, 3 resimden 2. Longboard Bearing Replacement Guide: adım 7, 3 resimden 3.
    • Put the outside spacer back on the axle of the board.
    • Put the wheel back on in the proper orientation.
    • The orientation depends on the wheel, but typically the decals face outward from the board.
    • You might need to use the pointed end on the small tool to move spacer on inside of the wheel to fit on the axle.
  8. Longboard Bearing Replacement Guide: adım 8, 2 resimden 1. Longboard Bearing Replacement Guide: adım 8, 2 resimden 2.
    • Using the 1/2" side of the Skate Tool, screw the nut back on the axle to hold the wheel in place.
  9. Longboard Bearing Replacement Guide: adım 9, 2 resimden 1. Longboard Bearing Replacement Guide: adım 9, 2 resimden 2.
    • Test the wheel by spinning it on the board to check that it moves freely.
    • If the wheel does not spin freely, the nut may be too tight. Loosen it just a little bit.
Sonuç
To replace the bearings on the other wheels, repeat steps.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Great article!
Kane Holland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 4,379
