Ana içeriğe geç
Longboard or Skateboard Truck Maintenance
Neye ihtiyacın var
  1. Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: adım 1, 2 resimden 1. Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: adım 1, 2 resimden 2.
    • Use a Phillips/flat head screw driver, along with a skate tool or set of pliers, to loosen the nuts which fasten the trucks to the deck.
  2. Longboard or Skateboard Truck Maintenance: adım 2, 1 resimden 1.
    • Use your fingers to fully loosen and remove the nuts from the bolts.
    • Nuts are small and easy to lose track of.
  3. Longboard or Skateboard Truck Maintenance: adım 3, 3 resimden 1. Longboard or Skateboard Truck Maintenance: adım 3, 3 resimden 2. Longboard or Skateboard Truck Maintenance: adım 3, 3 resimden 3.
    • Use your hands to remove the trucks from the deck.
    • Make sure the kingpin is facing outward, If the kingpin is not properly reinstalled, the trucks will fail to perform properly.
  4. Longboard or Skateboard Truck Maintenance: adım 4, 1 resimden 1.
    • Remove the truck raiser if applicable.
  5. Longboard or Skateboard Truck Maintenance: adım 5, 2 resimden 1. Longboard or Skateboard Truck Maintenance: adım 5, 2 resimden 2.
    • Remove the bolts from the factory drilled holes on the deck.
    • Note that the bolts are small and easy to lose track of.
  6. Longboard or Skateboard Truck Maintenance: adım 6, 1 resimden 1.
    • Clean the deck with a moist cloth or cleaning solution.
  7. Longboard or Skateboard Truck Maintenance: adım 7, 1 resimden 1.
    • Clean the trucks with a moist cloth or cleaning solution.
  8. Longboard or Skateboard Truck Maintenance: adım 8, 2 resimden 1. Longboard or Skateboard Truck Maintenance: adım 8, 2 resimden 2.
    • Clean the hardware by either soaking it in cleaning solution, or by manually cleaning it with a moist cloth.
  9. Longboard or Skateboard Truck Maintenance: adım 9, 1 resimden 1.
    • Repeat steps 1-7 with the second truck.
  10. Longboard or Skateboard Truck Maintenance: adım 10, 1 resimden 1.
    • After re-installation, check and confirm that all the bolts and nuts are tight. The bolts should be slightly submerged in the wood of the deck
    • Over tightening the bolts can cause them to strip.
    • Failure to tighten the bolts and nuts properly may lead to improper performance.
  11. Longboard or Skateboard Truck Maintenance: adım 11, 2 resimden 1. Longboard or Skateboard Truck Maintenance: adım 11, 2 resimden 2.
    • After re-installing the trucks, check and confirm the kingpin is facing outward.
    • Failure to do this will cause the longboard's functions to be inverted, which may lead to personal injury.
Sonuç
Now you’ve completed the guide ‘How to clean and maintain skate/longboard trucks. Your longboard should look like the picture. Before riding, as a final precaution, make sure every piece is securely fastened and the trucks are facing the correct way. Have fun and always wear a helmet!
Bir başkası bu kılavuzu tamamladı.
Dominic Turano
122 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 7,477
