Ana içeriğe geç
Lorex A-MPX IR Bullet Camera Disassembly
Neye ihtiyacın var
  1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: adım 1, 2 resimden 1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: adım 1, 2 resimden 2.
    • This little camera comes with the LHA4000 kit by Lorex.
    • It has a 4K sensor with motion sensor and infrared lights
  2. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: adım 2, 2 resimden 1. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: adım 2, 2 resimden 2.
    • Remove the 4 screws holding down the camera lens. They are standard Philipps #1
    • Be careful not to pull the sensor as it is still attached to the signal cables.
  3. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: adım 3, 3 resimden 1. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: adım 3, 3 resimden 2. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: adım 3, 3 resimden 3.
    • The system board is directly attached to the back of the lens.
    • The connector is a simple 4 wires. This make it very easy to repair.
  4. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: adım 4, 3 resimden 1. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: adım 4, 3 resimden 2. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: adım 4, 3 resimden 3.
    • There is a rubber grommet that keep moisture away from the inside of the board.
    • There IS also this sillica pack inside the camera if moisture ever breach in.
    • The base is fixed to the feet using a single Phillips #1 screw
    • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
  5. Lorex  A-MPX IR Bullet Camera Disassembly, Whole assembly: adım 5, 1 resimden 1.
    • Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
Sonuç
Hans
1.920 İtibar
6 adet Kılavuz yazıldı
Ekip
Mero IT Services Mero IT Services üyesi
Business
1 Üye
3 Yorum
Can you do disassembly video on Lorex C861MB camera ?
Mark Curry - Yanıt
Can you do a disassembly video on Lorex C861MB camera ?
Mark Curry - Yanıt
How much is this camera
Michael Teeter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 2,514
