Ana içeriğe geç
Lorex LW2742 LCD Display Replacement
Neye ihtiyacın var
    1. Lorex LW2742 LCD Display Replacement, Back Panel: adım 1, 3 resimden 1. Lorex LW2742 LCD Display Replacement, Back Panel: adım 1, 3 resimden 2. Lorex LW2742 LCD Display Replacement, Back Panel: adım 1, 3 resimden 3.
      • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
      • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
      FixBot'a Sor
      Yorum Ekle
    2. Lorex LW2742 LCD Display Replacement: adım 2, 1 resimden 1.
      • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
      FixBot'a Sor
      Yorum Ekle
    3. Lorex LW2742 LCD Display Replacement: adım 3, 2 resimden 1. Lorex LW2742 LCD Display Replacement: adım 3, 2 resimden 2.
      • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
      • Carefully remove the back panel
      • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
      FixBot'a Sor
      Yorum Ekle
    1. Lorex LW2742 LCD Display Replacement, LCD Display: adım 4, 3 resimden 1. Lorex LW2742 LCD Display Replacement, LCD Display: adım 4, 3 resimden 2. Lorex LW2742 LCD Display Replacement, LCD Display: adım 4, 3 resimden 3.
      • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
      FixBot'a Sor
      Yorum Ekle
    2. Lorex LW2742 LCD Display Replacement: adım 5, 1 resimden 1.
      • Remove the two 5mm Phillips #1 screws that are holding the motherboard in place.
      FixBot'a Sor
      Yorum Ekle
    3. Lorex LW2742 LCD Display Replacement: adım 6, 2 resimden 1. Lorex LW2742 LCD Display Replacement: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Peel away the yellow tape that is covering the large harness.
      • Use needle-nosed tweezers to pull out the black tabs that are holding the film in the harness and gently pull the film out of the harness.
      FixBot'a Sor
      Yorum Ekle
    4. Lorex LW2742 LCD Display Replacement: adım 7, 2 resimden 1. Lorex LW2742 LCD Display Replacement: adım 7, 2 resimden 2.
      • Flip the back panel and motherboard over to reveal the back of the LCD monitor
      FixBot'a Sor
      Yorum Ekle
    5. Lorex LW2742 LCD Display Replacement: adım 8, 2 resimden 1. Lorex LW2742 LCD Display Replacement: adım 8, 2 resimden 2.
      • The LCD monitor will easily come out of the front casing of the monitor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Kusmierz
601 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G1
4 Üyeler
12 adet Kılavuz yazıldı
4Kılavuz Yorumları
I need the price list of this Lorex LW2742 LCD Display Replacement
ADETAYO - Yanıt Paylaş
I have the Lorex and I need a new ftat flexible cable, the number on the cable is S13821. This cable broke off as i did not use Ifixit at first.
Pierre DePass - Yanıt Paylaş
I have the Lorex and I need a new flat flexible cable, the idea here was to get to the DC supply and remove the plug in component as it was damage because of constant useage of plug in in and out. The Flat Flexible Cable Number is S13821
I have a Loren 7'' wireless monitor and I need to get a replacement battery model 4170102 where can I get one
Micky Shoemaker - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 46
Her zaman: 2,000
