Ana içeriğe geç
Lorex LW2742 Microphone Replacement
Neye ihtiyacın var
  1. Lorex LW2742 Microphone Replacement, Microphone: adım 1, 2 resimden 1. Lorex LW2742 Microphone Replacement, Microphone: adım 1, 2 resimden 2.
    • Remove the six 10mm Torx T10 screws on camera face.
  2. Lorex LW2742 Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the exterior lens cover.
  3. Lorex LW2742 Microphone Replacement: adım 3, 3 resimden 1. Lorex LW2742 Microphone Replacement: adım 3, 3 resimden 2. Lorex LW2742 Microphone Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Microphone Replacement: adım 4, 1 resimden 1.
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the left and right 8mm screws first. Followed by the top and bottom 5mm screws.
  5. Lorex LW2742 Microphone Replacement: adım 5, 1 resimden 1.
  6. Lorex LW2742 Microphone Replacement: adım 6, 3 resimden 1. Lorex LW2742 Microphone Replacement: adım 6, 3 resimden 2. Lorex LW2742 Microphone Replacement: adım 6, 3 resimden 3.
    • Use tweezers to disconnect the microphone wires from the internal components of camera.
  7. Lorex LW2742 Microphone Replacement: adım 7, 3 resimden 1. Lorex LW2742 Microphone Replacement: adım 7, 3 resimden 2. Lorex LW2742 Microphone Replacement: adım 7, 3 resimden 3.
    • Remove the 4mm Flathead #4 screw on the bottom of the camera.
    • Remove the weatherproof gasket around the microphone with tweezers.
  8. Lorex LW2742 Microphone Replacement: adım 8, 3 resimden 1. Lorex LW2742 Microphone Replacement: adım 8, 3 resimden 2. Lorex LW2742 Microphone Replacement: adım 8, 3 resimden 3.
    • Remove the microphone.
    • Push the microphone from the inside out for easier removal.
Sonuç
Alex Kusmierz
601 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 276
