Ana içeriğe geç
Lorex LW2742 Night Vision IR LEDs Replacement
Neye ihtiyacın var
  1. Lorex LW2742 Night Vision IR LEDs Replacement, Night Vision IR LEDs: adım 1, 2 resimden 1. Lorex LW2742 Night Vision IR LEDs Replacement, Night Vision IR LEDs: adım 1, 2 resimden 2.
    • Remove the six 10mm Torx T10 screws on the camera face.
  2. Lorex LW2742 Night Vision IR LEDs Replacement: adım 2, 1 resimden 1.
    • Remove the exterior lens cover.
  3. Lorex LW2742 Night Vision IR LEDs Replacement: adım 3, 3 resimden 1. Lorex LW2742 Night Vision IR LEDs Replacement: adım 3, 3 resimden 2. Lorex LW2742 Night Vision IR LEDs Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Night Vision IR LEDs Replacement: adım 4, 2 resimden 1. Lorex LW2742 Night Vision IR LEDs Replacement: adım 4, 2 resimden 2.
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the top and bottom 5mm screws first, followed by the left and right 8mm screws.
  5. Lorex LW2742 Night Vision IR LEDs Replacement: adım 5, 2 resimden 1. Lorex LW2742 Night Vision IR LEDs Replacement: adım 5, 2 resimden 2.
    • Use tweezers to unclip the cables to the LED board
Sonuç
craig crisci
220 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,032
