Ana içeriğe geç
Lorex LW2742 Speaker Replacement
Neye ihtiyacın var
  1. Lorex LW2742 Speaker Replacement, Back Panel: adım 1, 3 resimden 1. Lorex LW2742 Speaker Replacement, Back Panel: adım 1, 3 resimden 2. Lorex LW2742 Speaker Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 Speaker Replacement: adım 3, 2 resimden 1. Lorex LW2742 Speaker Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 Speaker Replacement, Speaker: adım 4, 3 resimden 1. Lorex LW2742 Speaker Replacement, Speaker: adım 4, 3 resimden 2. Lorex LW2742 Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 Speaker Replacement: adım 5, 2 resimden 1. Lorex LW2742 Speaker Replacement: adım 5, 2 resimden 2.
    • Using a metal spudger, pry the melted black plastic away from the speaker.
    • Carefully pull the speaker out of its housing by the wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Kusmierz
601 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 221
