Ana içeriğe geç
Lorex MC6950 Camera Lens Replacement
Neye ihtiyacın var
  1. Lorex MC6950 Camera Lens Replacement, Camera Lens: adım 1, 2 resimden 1. Lorex MC6950 Camera Lens Replacement, Camera Lens: adım 1, 2 resimden 2.
    • To remove a bad lens, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
  2. Lorex MC6950 Camera Lens Replacement: adım 2, 2 resimden 1. Lorex MC6950 Camera Lens Replacement: adım 2, 2 resimden 2.
    • Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
    • Once the camera is removed, remove the wires from the outer containment shell.
    • Be careful. The metal spudger could damage the camera if not handled with care.
  3. Lorex MC6950 Camera Lens Replacement: adım 3, 2 resimden 1. Lorex MC6950 Camera Lens Replacement: adım 3, 2 resimden 2.
    • With the camera in hand, the circuit board must be separated from the LED containment shell. There is a 5mm JIS 0 screw at every corner of the circuit board.
    • The wires attaching the circuit board to the shell should be removed as well.
  4. Lorex MC6950 Camera Lens Replacement: adım 4, 1 resimden 1.
    • Now the motor housing must be removed from the circuit board first as it is in the way of the screws associated with the lens. There are three 5mm JIS 0 screws located on the lens side of the circuit board to remove the motor.
  5. Lorex MC6950 Camera Lens Replacement: adım 5, 1 resimden 1.
    • The lens has two 5 mm JIS 0 screws located under the motor's previous location. Once these are removed, the lens can be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elijah Conlin
379 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Fall 2017 IUPUI, Team S2-G2, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 869
