Ana içeriğe geç
Lubricate General Electric Telephone 2-9710A Tuning Slider
Neye ihtiyacın var
  1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Phone Cord: adım 1, 2 resimden 1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Phone Cord: adım 1, 2 resimden 2.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Lubricate General Electric Telephone 2-9710A Tuning Slider: adım 2, 3 resimden 1. Lubricate General Electric Telephone 2-9710A Tuning Slider: adım 2, 3 resimden 2. Lubricate General Electric Telephone 2-9710A Tuning Slider: adım 2, 3 resimden 3.
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Lubricate General Electric Telephone 2-9710A Tuning Slider, 9V Base Battery: adım 3, 2 resimden 1. Lubricate General Electric Telephone 2-9710A Tuning Slider, 9V Base Battery: adım 3, 2 resimden 2.
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Volume Dial: adım 4, 2 resimden 1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Volume Dial: adım 4, 2 resimden 2.
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Screws on the Back: adım 5, 1 resimden 1.
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Lubricate General Electric Telephone 2-9710A Tuning Slider, Pry the Back Off: adım 6, 2 resimden 1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Pry the Back Off: adım 6, 2 resimden 2.
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. Lubricate General Electric Telephone 2-9710A Tuning Slider, Lubricate General Electric Telephone 2-9710A Tuning Slider: adım 7, 2 resimden 1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Lubricate General Electric Telephone 2-9710A Tuning Slider: adım 7, 2 resimden 2.
    • Turn the tuning slider counterclockwise until the slider stops.
    • Apply lubricant to the slider rail.
    • Turn the tuning slider back and forth to distribute the lubricant.
    • Make sure the lubricant does not touch the circuit board. This can damage the circuit board.
Sonuç
Alles Rebel
72 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G59
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 833
