Ana içeriğe geç
M3D Micro Fan Replacement
Neye ihtiyacın var
  1. M3D Micro Fan Replacement, Fan: adım 1, 3 resimden 1. M3D Micro Fan Replacement, Fan: adım 1, 3 resimden 2. M3D Micro Fan Replacement, Fan: adım 1, 3 resimden 3.
    • To release the x-rods, pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks.
    FixBot'a Sor
    Yorum Ekle
  2. M3D Micro Fan Replacement: adım 2, 3 resimden 1. M3D Micro Fan Replacement: adım 2, 3 resimden 2. M3D Micro Fan Replacement: adım 2, 3 resimden 3.
    • Slide the tracks off the second slider and remove the printer head and x-tracks from the center of the printer. To remove the front cover of the print head, firmly grip the cover and gently pull it off.
    FixBot'a Sor
    Yorum Ekle
  3. M3D Micro Fan Replacement: adım 3, 2 resimden 1. M3D Micro Fan Replacement: adım 3, 2 resimden 2.
    • Disconnect the red and black wires at the white connector. They should easily separate.
    FixBot'a Sor
    Yorum Ekle
  4. M3D Micro Fan Replacement: adım 4, 3 resimden 1. M3D Micro Fan Replacement: adım 4, 3 resimden 2. M3D Micro Fan Replacement: adım 4, 3 resimden 3.
    • The fan is held loosely in place at the base of the printer head. Use a metal spudger to gently pry it out of the printer head.
    FixBot'a Sor
    Yorum Ekle
  5. M3D Micro Fan Replacement: adım 5, 1 resimden 1.
    • Pull the fan all the way out of the printer head.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Yuliya Marusyk
285 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 46
Her zaman: 1,583
