Ana içeriğe geç
M3D Micro Motor Replacement
Neye ihtiyacın var
  1. M3D Micro Motor Replacement, M3D Micro Frame Removal: adım 1, 1 resimden 1.
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Motor Replacement: adım 2, 3 resimden 1. M3D Micro Motor Replacement: adım 2, 3 resimden 2. M3D Micro Motor Replacement: adım 2, 3 resimden 3.
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
  3. M3D Micro Motor Replacement: adım 3, 2 resimden 1. M3D Micro Motor Replacement: adım 3, 2 resimden 2.
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
  4. M3D Micro Motor Replacement, Motor: adım 4, 1 resimden 1.
    • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
  5. M3D Micro Motor Replacement: adım 5, 2 resimden 1. M3D Micro Motor Replacement: adım 5, 2 resimden 2.
    • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
  6. M3D Micro Motor Replacement: adım 6, 2 resimden 1. M3D Micro Motor Replacement: adım 6, 2 resimden 2.
    • Once disconnected you will proceed to lift the motor using pliers.
  7. M3D Micro Motor Replacement: adım 7, 2 resimden 1. M3D Micro Motor Replacement: adım 7, 2 resimden 2.
    • Now, remove the motor.
Sonuç
Miguel Pina
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G2
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,598
