Ana içeriğe geç
MAGNAVOX MDV2300 Power Cord Replacement
Neye ihtiyacın var
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: adım 2, 1 resimden 1.
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: adım 4, 1 resimden 1.
  5. MAGNAVOX MDV2300 Power Cord Replacement: adım 5, 2 resimden 1. MAGNAVOX MDV2300 Power Cord Replacement: adım 5, 2 resimden 2.
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: adım 6, 1 resimden 1.
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: adım 7, 1 resimden 1.
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
Sonuç
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Justin
298 İtibar
2 adet Kılavuz yazıldı
Ekip
Penn State, Team 1-41, Kaschak Winter 2015 Penn State, Team 1-41, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S1G41
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 514
