Ana içeriğe geç
MFC-J4410DW Flushing Box Replacement
Neye ihtiyacın var
  1. MFC-J4410DW Flushing Box Replacement, Preparation: adım 1, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Preparation: adım 1, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Preparation: adım 1, 3 resimden 3.
    • Before beginning disassembly, turn off the printer and unplug the power cord.
    • Open the front access door and remove any cards or cables present. Close the access door.
    • Remove the paper tray.
    • Remove the ink cartridges.
    • You may wish to install the Protective Part to prevent the ink tubes from drying while the cartridges are removed.
    • Open the printer cover using the finger holds on the sides.
    • Unplug and remove any cords present under the cover.
    • Remove the LAN port and EXT port caps (if present).
  2. MFC-J4410DW Flushing Box Replacement, Removing the cover support: adım 2, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the cover support: adım 2, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Removing the cover support: adım 2, 3 resimden 3.
    • While holding the cover with one hand, pull the hook on the back of the support damper, then remove the damper from the cover.
    • Remove the damper from the support.
    • Turn the support upright and pull it straight out of the printer.
  3. MFC-J4410DW Flushing Box Replacement, Removing the harness cover: adım 3, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the harness cover: adım 3, 2 resimden 2.
    • Use your finger or a spudger to unhook the two tabs on the right side of the harness cover by levering it up.
    • Remove the harness cover. There are two tabs on the left side that you have to wiggle free, and one on the front.
  4. MFC-J4410DW Flushing Box Replacement, Removing the grounding screw: adım 4, 1 resimden 1.
    • Remove the 6 mm Phillips #2 screw from the grounding wire of the ADF motor harness.
    • Torque: 0.40±0.10 N•m
    • The Brother service manual lists torques for all screws, but proper torque should not be necessary.
  5. MFC-J4410DW Flushing Box Replacement: adım 5, 1 resimden 1.
    • In the proceeding steps, you will disconnect the following cables:
    • CIS flat cable
    • Scanner motor harness
    • ADF motor harness
    • Document detection/document scanning position sensor harness
  6. MFC-J4410DW Flushing Box Replacement: adım 6, 1 resimden 1.
    • Pull the CIS flat cable out of its socket.
    • Pull all flat cables directly up out of their sockets, pulling on the cables themselves at the blue tabs.
  7. MFC-J4410DW Flushing Box Replacement: adım 7, 1 resimden 1.
    • Pull the scanner motor harness out of its socket.
  8. MFC-J4410DW Flushing Box Replacement: adım 8, 1 resimden 1.
    • Pull the ADF motor harness out of its socket.
  9. MFC-J4410DW Flushing Box Replacement: adım 9, 1 resimden 1.
    • Pull the document detection/document scanning position sensor harness out of its sockets.
  10. MFC-J4410DW Flushing Box Replacement, Opening the scanner harness holder: adım 10, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Opening the scanner harness holder: adım 10, 2 resimden 2.
    • Insert a spudger between the scanner harness holder and frame to release the tab. There is a second tab on the opposite side.
    • Lift the scanner harness holder out of its frame.
    • Reassembly Note: Before reattaching the harness holder, it is advisable to reattach the cover support (Step 2) to minimize tension on the wiring harnesses.
  11. MFC-J4410DW Flushing Box Replacement, Securing the scanner harness holder: adım 11, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Securing the scanner harness holder: adım 11, 2 resimden 2.
    • Push on the tab to secure the scanner harness holder to the scanner cover.
    • De-route the document detection/document scanning position sensor harness and the ADF motor harness from the scanner harness holder.
    • During reassembly, put a 20mm-thick pad (book, stack of paper) on the scanner glass, close the scanner cover, then route the document detection/document scanning position sensor harness and the ADF motor harness through the harness holder. This will ensure the proper harness tension to allow scanning of thick books.
  12. MFC-J4410DW Flushing Box Replacement, Removing the scanner cover: adım 12, 1 resimden 1.
    • Using both hands, pull the scanner cover to the rear while holding it vertically, then lift it off of the printer.
  13. MFC-J4410DW Flushing Box Replacement, Removing the upper cover: adım 13, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the upper cover: adım 13, 2 resimden 2.
    • Remove the six 12 mm Phillips #2 screws securing the upper cover to the printer.
    • Torque: 0.70±0.10 N•m
    • Pull off the upper cover.
    • When reinstalling, ensure that the control panel wiring holder slides into its slot on the upper cover.
  14. MFC-J4410DW Flushing Box Replacement, Removing the ink absorber box wiring: adım 14, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the ink absorber box wiring: adım 14, 2 resimden 2.
    • Remove the ink absorber full sensor from its socket.
    • De-route the wiring from its harness.
  15. MFC-J4410DW Flushing Box Replacement, Unhooking the ink absorber: adım 15, 1 resimden 1.
    • Unclip the ink absorber from the harness by pulling it up and to the right.
  16. MFC-J4410DW Flushing Box Replacement, Removing the MJ flat cable: adım 16, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the MJ flat cable: adım 16, 2 resimden 2.
    • Remove the MJ PCB flat cable.
    • De-route the MJ PCB flat cable.
  17. MFC-J4410DW Flushing Box Replacement, Removing the MJ shield: adım 17, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the MJ shield: adım 17, 2 resimden 2.
    • Remove the 6 mm Phillips #2 screw securing the MJ shield.
    • Remove the MJ shield.
  18. MFC-J4410DW Flushing Box Replacement: adım 18, 1 resimden 1.
    • Remove the 6 mm Phillips #2 screw securing the MJ PCB assembly.
  19. MFC-J4410DW Flushing Box Replacement, Removing the MJ PCB assembly: adım 19, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the MJ PCB assembly: adım 19, 2 resimden 2.
    • Pull back on the MJ PCB assembly release tab.
    • Remove the MJ PCB assembly.
  20. MFC-J4410DW Flushing Box Replacement, Removing the front cover: adım 20, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the front cover: adım 20, 2 resimden 2.
    • Release the upper hook on the front cover.
    • Pry the front cover off. Note the tab on the left side of the cover.
  21. MFC-J4410DW Flushing Box Replacement, Removing the inner media module cover: adım 21, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the inner media module cover: adım 21, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Removing the inner media module cover: adım 21, 3 resimden 3.
    • Open the media module cover.
    • Release the two hooks holding the inner media module cover to the printer.
    • Remove the inner media module cover.
    • You can close the media module cover after this to get it out of the way.
  22. MFC-J4410DW Flushing Box Replacement: adım 22, 1 resimden 1.
    • Remove the power supply PCB harness from the main PCB assembly and de-route it from the main PCB frame.
  23. MFC-J4410DW Flushing Box Replacement: adım 23, 1 resimden 1.
    • Remove the following wiring harnesses from the sensor relay PCB assembly, and de-route them from the main PCB frame:
    • Paper feed encoder sensor harness
    • Switchback sensor harness
    • It may be easier to wait to de-route the carriage motor harness and paper feed motor harness before de-routing the switchback sensor harness.
  24. MFC-J4410DW Flushing Box Replacement: adım 24, 1 resimden 1.
    • Remove the following wiring harnesses from the main PCB assembly and de-route them from the main PCB frame:
    • In the process of de-routing these harnesses, pull straight up on the attached magnets to dislodge them from their retainers.
    • Paper feed motor harness
    • Carriage motor harness
  25. MFC-J4410DW Flushing Box Replacement: adım 25, 3 resimden 1. MFC-J4410DW Flushing Box Replacement: adım 25, 3 resimden 2. MFC-J4410DW Flushing Box Replacement: adım 25, 3 resimden 3.
    • Remove the control panel flat cable.
    • Remove the ink refill sensor flat cable.
    • Remove the following cables:
    • Carriage PCB flat cable 1
    • Carriage PCB flat cable 2
    • Carriage PCB flat cable 3
  26. MFC-J4410DW Flushing Box Replacement: adım 26, 1 resimden 1.
    • Remove the following wiring harnesses attached to the main PCB frame:
    • Speaker harness
    • Ink cover sensor harness
    • Purge cam sensor harness
    • Registration sensor harness
  27. MFC-J4410DW Flushing Box Replacement: adım 27, 1 resimden 1.
    • Remove the 6 mm Phillips #2 screw securing the control panel grounding wire.
  28. MFC-J4410DW Flushing Box Replacement: adım 28, 2 resimden 1. MFC-J4410DW Flushing Box Replacement: adım 28, 2 resimden 2.
    • Remove two 10 mm Phillips #2 screws securing the main PCB frame.
    • Remove the final 6 mm Phillips #2 screw securing the main PCB frame.
    • Torque: 0.45±0.10 N•m
  29. MFC-J4410DW Flushing Box Replacement, Removing the main PCB frame: adım 29, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the main PCB frame: adım 29, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Removing the main PCB frame: adım 29, 3 resimden 3.
    • Remove the 6 mm Phillips #2 screw securing the FG wire.
    • Unhook the tab of the clear plastic wiring holder.
    • During reassembly, ensure that the plastic tab on the right goes into the slot behind the flat cables.
    • Remove the main PCB frame.
    • Before reinstalling, ensure that the ink tubes beneath are not crimped.
  30. MFC-J4410DW Flushing Box Replacement: adım 30, 3 resimden 1. MFC-J4410DW Flushing Box Replacement: adım 30, 3 resimden 2. MFC-J4410DW Flushing Box Replacement: adım 30, 3 resimden 3.
    • De-route the switchback sensor harness (black) and the paper feed motor harness (red and black) from the left side of the tube support plate.
    • De-route the speaker harness (red and black), purge cam sensor harness (white, three-wire), registration sensor harness (orange), ink cover sensor harness (white, two-wire), carriage motor harness (red and black), and FG wire (green) from the right side of the tube support plate.
    • De-route the ink refill sensor flat cable from the tube support plate.
  31. MFC-J4410DW Flushing Box Replacement: adım 31, 3 resimden 1. MFC-J4410DW Flushing Box Replacement: adım 31, 3 resimden 2. MFC-J4410DW Flushing Box Replacement: adım 31, 3 resimden 3.
    • Remove the left 10 mm Phillips #2 screw holding down the tube support plate.
    • Remove the center 10 mm Phillips #2 screw holding down the tube support plate.
    • Remove the right 10 mm Phillips #2 screw holding down the tube support plate.
    • Torque for all three screws: 0.40±0.10 N•m
  32. MFC-J4410DW Flushing Box Replacement, Removing the tube support plate: adım 32, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the tube support plate: adım 32, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Removing the tube support plate: adım 32, 3 resimden 3.
    • Tilt open the control panel to release the tilt hook stopper.
    • There's a button on the underside of the control panel to allow it to fold back in.
    • Release the retaining tab with your finger or a metal spudger.
    • Remove the tube support plate.
    • There's no need to remove the ink tubes and flat harnesses. Just set the tube support plate out of the way on the printer. Take care not to crimp the ink tubes.
    • When reinstalling, make sure the black switchback sensor harness does not get left under the tube support plate.
  33. MFC-J4410DW Flushing Box Replacement, Removing the lower right side cover: adım 33, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the lower right side cover: adım 33, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Removing the lower right side cover: adım 33, 3 resimden 3.
    • Open the jam clear cover.
    • Push the lower right side cover in the direction of the arrow to release its hooks from the printer. A metal spudger may be of use here.
    • Pull the lower right side cover to the rear to release its hooks and remove it from the printer. Again, using a metal spudger to pry it to the rear may be useful.
  34. MFC-J4410DW Flushing Box Replacement: adım 34, 2 resimden 1. MFC-J4410DW Flushing Box Replacement: adım 34, 2 resimden 2.
    • De-route the FG wire (green), the purge cam sensor harness (white), and the registration sensor harness (orange) from the right side of the machine.
    • Remove the magnet attached to the carriage motor harness (red and black) from its slot.
  35. MFC-J4410DW Flushing Box Replacement: adım 35, 1 resimden 1.
    • Remove the left carriage frame spring by pulling back on the tab on the bottom.
  36. MFC-J4410DW Flushing Box Replacement, Moving the head/carriage unit: adım 36, 3 resimden 1. MFC-J4410DW Flushing Box Replacement, Moving the head/carriage unit: adım 36, 3 resimden 2. MFC-J4410DW Flushing Box Replacement, Moving the head/carriage unit: adım 36, 3 resimden 3.
    • Turn the paper feed roller gear in the direction of the arrow until the head stopper of the maintenance unit clicks.
    • From this step on, it might be a good idea to wear nitrile gloves to protect your hands from ink stains. But don't worry; they wash off easily.
    • Slide the head/carriage unit to the removal slot position at the far left. Don't remove it yet.
    • This is the removal slot.
  37. MFC-J4410DW Flushing Box Replacement: adım 37, 1 resimden 1.
    • Remove the right carriage frame spring.
  38. MFC-J4410DW Flushing Box Replacement: adım 38, 1 resimden 1.
    • Remove the two 10 mm Phillips #2 screws holding down the carriage frame assembly.
    • Torque: 0.60±0.10 N•m
  39. MFC-J4410DW Flushing Box Replacement, Removing the carriage frame assembly: adım 39, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the carriage frame assembly: adım 39, 2 resimden 2.
    • Lift the carriage frame assembly out of the printer, making sure to keep the head/carriage unit over its release slots.
    • When reinstalling, make sure it's seated properly. It may require some wiggling, but it will fit firmly when placed correctly.
    • Note these hooks, which have to be disengaged from the switchback frame assembly in front of it during removal. Just wiggle the carriage frame assembly around while lifting, and they should come loose.
  40. MFC-J4410DW Flushing Box Replacement, Removing the flushing base: adım 40, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the flushing base: adım 40, 2 resimden 2.
    • Remove the flushing base by lifting it straight upwards.
    • You'll want a folded tissue or paper towel to set this down on.
    • The flushing base, removed.
  41. MFC-J4410DW Flushing Box Replacement, Removing the flushing box: adım 41, 2 resimden 1. MFC-J4410DW Flushing Box Replacement, Removing the flushing box: adım 41, 2 resimden 2.
    • Remove the flushing box by disengaging the front hook, then tilting it up to disengage the rear hook.
    • When reinstalling, just press it straight down.
    • The flushing box, removed.
Sonuç
To reassemble your device, follow these instructions in reverse order. If you haven’t already, it’s recommended that you also replace the ink absorber box during reassembly.
Screw torques from the service manual have been included if you happen to have a torque screwdriver, but don’t worry about them if you don’t.
After reassembly, follow the following steps to reset the purge count in order to clear the “Ink Absorber Full” error:
  1. Plug the printer in and turn it on.
  2. Press the Home button (the house icon) on the front of the printer until the Maintenance Mode screen appears (approximately five seconds).
  3. Hold down the blank button at the bottom of the screen until a number keypad appears on the screen (approximately two seconds).
  4. Press *******, 286 and 4 (you can use the onscreen keypad or the printer’s built-in keypad for this). The printer will beep and MAINTENANCE will appear on the screen.
  5. Press 8 and 0.
  6. Press the down arrow repeatedly until PURGE: (or FLUSHING:) appears on the screen.
  7. Press 278 and 3. The printer will beep and MAINTENANCE will again appear on the screen.
  8. Press 9 twice to exit maintenance mode and reboot the printer. You can also use this to start over if you make an error.
If this guide was helpful, why not buy the author a coffee?
21 farklı kişi bu kılavuzu tamamladı.
Calion
3.983 İtibar
3 adet Kılavuz yazıldı
Ekip
Syler Solutions Syler Solutions üyesi
Business
1 Üye
13 adet Kılavuz yazıldı
14Kılavuz Yorumları
Hi there.
Great guide - although some pics of re-assembly and re-routing of the cables that were de-routed would have been very helpful. I am a complete novice and I followed this guide to the letter. I was successful in installing both boxes and re-assembling the printer so that on my initial power up it showed a fully usable touchscreen. However I then had a problem where it would not detect (any of) the ink cartridges.
I thought it might have been a loose connection and went as far back as re-seating the connections on the main PCB frame. After that the touchscreen display just remained blank.
I can’t think what I could have screwed up in re-seating things. One step forward - two steps back !
If anyone reads this and has some idea I would appreciate any assistance.
Cheers
S
JK SS - Yanıt
When fixing the tube support plate be careful to have the blck cables of the switchback sensor harness pulled out as far as possible, it will be stuck under the plate and too short to plug it in again.
Bernd
Bernd Gruber - Yanıt
bonjour.
Excellent guide -j’ai le MFC-J6520dw il est tout a fait compatible.mais j’ai un autre probleme “please dl rom” j’ai meme mis a jour le firmware.bonne journée et merci
Mokhtaaar j
m
Mokhtar - Yanıt
Désolé, je ne peux pas vous aider avec le problème "dl rom". Peut-être demander dans les forums? (Ceci provient de Google Translate; j'espère que cela a du sens.)
Calion -
Great guide.
Take care when replacing the 'carriage frame assembly' as I had continual paper jams on initial reassembly. I completed another tear down to get at this part and re-seat it properly (just more jiggling until satisfied that it was well seated). All good then. Also, I don't believe I had to carry out the second part of point no. 11.
Seamus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 64
Son 30 gün: 286
Her zaman: 18,777
