Ana içeriğe geç
MID-7006 Battery Replacement
Neye ihtiyacın var
    1. MID-7006 Battery Replacement, Battery: adım 1, 2 resimden 1. MID-7006 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Use the plastic opening tool to pull the screen away from the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. MID-7006 Battery Replacement: adım 2, 2 resimden 1. MID-7006 Battery Replacement: adım 2, 2 resimden 2.
      • Once you have seperated the back plate and the screen from each other like so, you will then begin to lift the battery peeling it off of its sticky pads.
      FixBot'a Sor
      Yorum Ekle
    3. MID-7006 Battery Replacement: adım 3, 2 resimden 1. MID-7006 Battery Replacement: adım 3, 2 resimden 2.
      • Unplug the battery at the plug indicated by the plastic opening tool. (The best way to do this is to place a finger on both sides of the plug and pull out gently) Once you have removed the old battery, plug the new battery into the same plug the old one came from.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Derrick Gholston
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 38-1, Bennett Fall 2016 Texas Tech, Team 38-1, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S38G1
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 556
