Ana içeriğe geç
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
Neye ihtiyacın var
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: adım 1, 1 resimden 1.
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 2, 1 resimden 1.
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 3, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 3, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 3, 3 resimden 3.
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 4, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 4, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 4, 3 resimden 3.
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 5, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 5, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 5, 3 resimden 3.
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 6, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 6, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 6, 3 resimden 3.
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 7, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 7, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 7, 3 resimden 3.
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 8, 2 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 8, 2 resimden 2.
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 9, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 9, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 9, 3 resimden 3.
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 10, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 10, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 10, 3 resimden 3.
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 11, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 11, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 11, 3 resimden 3.
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 12, 3 resimden 1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 12, 3 resimden 2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 12, 3 resimden 3.
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: adım 13, 1 resimden 1.
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
Sonuç
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
217 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 799
