Ana içeriğe geç
MSI GE62 6QF Apache Pro Bottom Case Replacement
Neye ihtiyacın var
  1. MSI GE62 6QF Apache Pro Bottom Case Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Bottom Case Replacement: adım 2, 1 resimden 1.
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Bottom Case Replacement, Bottom Case: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Bottom Case Replacement: adım 4, 3 resimden 1. MSI GE62 6QF Apache Pro Bottom Case Replacement: adım 4, 3 resimden 2. MSI GE62 6QF Apache Pro Bottom Case Replacement: adım 4, 3 resimden 3.
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Bottom Case Replacement: adım 5, 2 resimden 1. MSI GE62 6QF Apache Pro Bottom Case Replacement: adım 5, 2 resimden 2.
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justice Owens
604 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Passmore Fall 2017 USF Tampa, Team S2-G3, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 5,289
