Ana içeriğe geç
MSI GE62 6QF Apache Pro Hard Drive Replacement
Neye ihtiyacın var
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 4, 3 resimden 1. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 4, 3 resimden 2. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 5, 2 resimden 1. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 5, 2 resimden 2.
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: adım 6, 3 resimden 1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: adım 6, 3 resimden 2. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: adım 6, 3 resimden 3.
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 2. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 3.
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 8, 2 resimden 1. MSI GE62 6QF Apache Pro Hard Drive Replacement: adım 8, 2 resimden 2.
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Justice Owens
604 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Passmore Fall 2017 USF Tampa, Team S2-G3, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G3
3 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - Yanıt
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - Yanıt
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - Yanıt
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 51
Her zaman: 8,241
