Ana içeriğe geç
MSI GE62 Apache Pro 004 Motherboard Replacement
Neye ihtiyacın var
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 2, 2 resimden 1. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 3, 3 resimden 1. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 3, 3 resimden 2. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 5, 3 resimden 1. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 5, 3 resimden 2. MSI GE62 Apache Pro 004 Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Sonuç
Alexander
86 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S15G5
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,962
