Ana içeriğe geç
MSI GE62 Apache Pro 004 Speakers Replacement
Neye ihtiyacın var
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: adım 2, 2 resimden 1. MSI GE62 Apache Pro 004 Speakers Replacement: adım 2, 2 resimden 2.
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: adım 3, 3 resimden 1. MSI GE62 Apache Pro 004 Speakers Replacement: adım 3, 3 resimden 2. MSI GE62 Apache Pro 004 Speakers Replacement: adım 3, 3 resimden 3.
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: adım 4, 3 resimden 1. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: adım 4, 3 resimden 2. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: adım 4, 3 resimden 3.
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: adım 5, 2 resimden 1. MSI GE62 Apache Pro 004 Speakers Replacement: adım 5, 2 resimden 2.
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Sonuç
Majid Al Hashmi
283 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S15G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,521
