Ana içeriğe geç
MSI GE70 2PE Apache Pro Touchpad Replacement
Neye ihtiyacın var
  1. MSI GE70 2PE Apache Pro Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over the laptop so the battery compartment is facing up.
  2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 2, 1 resimden 1.
    • Push the right latch all the way to the right until it clicks into place.
  3. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 3, 1 resimden 1.
    • Pull and hold the left latch.
  4. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 4, 1 resimden 1.
    • Pry the battery upward using the indent.
  5. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 5, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 5, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 5, 3 resimden 3.
    • Continue to pull the battery until it is free of the casing.
  6. MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: adım 6, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: adım 6, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: adım 6, 3 resimden 3.
    • Remove the six 5.5mm screws by using a Phillips #1 screwdriver.
    • Pry the door off using a plastic opening tool.
  7. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 7, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 7, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 7, 3 resimden 3.
    • Remove the five 3.5mm screws by using a Phillips #1 screwdriver.
  8. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 8, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 8, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 8, 3 resimden 3.
    • Remove the twenty-one 5.5mm screws by using a Phillips #1 screwdriver.
  9. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 9, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 9, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 9, 3 resimden 3.
    • Disconnect the power, mic, and LVDS cables.
  10. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 10, 1 resimden 1.
    • Turn over the laptop so the screen is open and keyboard is exposed.
  11. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 11, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 11, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 11, 3 resimden 3.
    • Remove the two 5.5mm screws by using a Phillips #1 screwdriver.
  12. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 12, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 12, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 12, 3 resimden 3.
    • Disconnect the touchpad, touchpad button, and power board connections.
  13. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 13, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 13, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 13, 3 resimden 3.
    • Using the plastic opening tool, pry open the computer case.
  14. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 14, 2 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 14, 2 resimden 2.
    • Turn the panel over so that the internals are facing upward.
  15. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 15, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 15, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 15, 3 resimden 3.
    • Remove the five 2.5mm screws by using a Phillips #1 screwdriver.
  16. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 16, 3 resimden 1. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 16, 3 resimden 2. MSI GE70 2PE Apache Pro Touchpad Replacement: adım 16, 3 resimden 3.
    • Using the plastic opening tool, pry the touchpad off and remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Do you know where the replacement touchpads for MSI laptops can be purchased? The touchpad getting stuck seems to be a common issue on their forums
Connor D - Yanıt
i looking for touchpad part also…
Rafał Pawlak -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 28
Her zaman: 4,068
