Ana içeriğe geç
MSI GE72 6QF Apache Pro Battery Replacement
Neye ihtiyacın var
  1. MSI GE72 6QF Apache Pro Battery Replacement, Battery: adım 1, 2 resimden 1. MSI GE72 6QF Apache Pro Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Battery Replacement: adım 2, 1 resimden 1.
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Battery Replacement: adım 4, 2 resimden 1. MSI GE72 6QF Apache Pro Battery Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Battery Replacement: adım 5, 2 resimden 1. MSI GE72 6QF Apache Pro Battery Replacement: adım 5, 2 resimden 2.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Battery Replacement: adım 6, 2 resimden 1. MSI GE72 6QF Apache Pro Battery Replacement: adım 6, 2 resimden 2.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Hovik Aklyan
233 İtibar
1 Kılavuz yazıldı
4 Yorum
hi there, can we use the laptop without the battery attached? i mean using only the power adaptor straight through the electric plug
San - Yanıt
yes you can, might drop bit of performance if you have Hybrid power management on, buyed my laptop used its 4 years old now and was used 2 years, dont even checked used battery but removed it and using AC power, just after a while gonna need to replace vents…
also cooling is problem in summers, cut-off some plastics and using cooling pad (recommending with 3+ vents or good airflow)
Ivars Kemers -
Faut démonter TOUTES les vis ??? Je vais en perdre la moitié !
Bravo!! plus simple c’était pas possibles?
Dire qu’avant on avait une trappe coulissante d’acces (DELL) ..
Bruno R - Yanıt
Les PC portables MSI ne sont pas les pire à réparer, loin de là !
Par expérience, l’étape la plus délicate c’est d’arriver à enlever le capot car il est maintenu par des clips en plastique, après on a accès à pratiquement toutes les pièces sur ce modèle.
Aujourd’hui, les PC portables avec une trappe coulissante existent toujours, mais ils sont cher :)
Brendan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 68
Her zaman: 10,186
