Giriş
This guide will show you how to replace the fans in your MSI GE72 6QF Apache Pro.
Neye ihtiyacın var
With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
20 farklı kişi bu kılavuzu tamamladı.
9Kılavuz Yorumları
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Where can I buy new fans?
Where do you buy the replacement fans
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
