Ana içeriğe geç
MSI GE72 6QF Apache Pro Hard Drive Replacement
Neye ihtiyacın var
  1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: adım 1, 2 resimden 1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 4, 2 resimden 1. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 5, 2 resimden 1. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 6, 2 resimden 1. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 6, 2 resimden 2.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Remove the two 5.5mm screws with the Phillips #1 screwdriver.
  8. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 8, 2 resimden 1. MSI GE72 6QF Apache Pro Hard Drive Replacement: adım 8, 2 resimden 2.
    • Gently pull out the hard drive by wiggling it from right to left with your hands until it is removed.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Tanmay Kumar
458 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G4
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
I have just bought an MSI GP72VR Laptop and I screwed up and got the model with only one drive, an SSD. It nagged at me that I didn't get the one with 2 drives. Well I happen to build my own desktops and had a spare 500GB Mushkin SSD hanging around and decided, what the heck. I came here and couldn't find the exact model but this is identical for what I want. I have never seen an access like this where you have to remove 19 screws. So I am very happy that this is on iFixit. I removed the screws and couldn't get the bottom removed as shown, I had to go to the other side and then it came off fairly easily. I used a butter knife for the initial pry and that worked well. They had sent the disk holder with the computer so I had no problem installing and I just set it up in Disk Manager. Tanmay, thank you very much for the assist, it is appreciated.
adard745 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 7,567
