Ana içeriğe geç
MSI GE72 6QF Apache Pro Optical Drive Replacement
Neye ihtiyacın var
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: adım 1, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 2, 1 resimden 1.
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 4, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 5, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 6, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 6, 2 resimden 2.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: adım 7, 3 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: adım 7, 3 resimden 2. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: adım 7, 3 resimden 3.
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Why do you have to remove the battery first?
Kevin - Yanıt
So you don’t have power running through it while working on it.
croberts1290 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 1,447
