Ana içeriğe geç
MSI GE72 6QF Apache Pro Optical Drive Replacement
Neye ihtiyacın var
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: adım 1, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 2, 1 resimden 1.
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 4, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 5, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 6, 2 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement: adım 6, 2 resimden 2.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: adım 7, 3 resimden 1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: adım 7, 3 resimden 2. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: adım 7, 3 resimden 3.
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Why do you have to remove the battery first?
Kevin - Yanıt
So you don’t have power running through it while working on it.
croberts1290 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,691
