Ana içeriğe geç
MSI GE72 6QF Apache Pro RAM Replacement
Neye ihtiyacın var
  1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: adım 1, 2 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro RAM Replacement: adım 2, 1 resimden 1.
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro RAM Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro RAM Replacement: adım 4, 2 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro RAM Replacement: adım 5, 2 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement: adım 5, 2 resimden 2.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro RAM Replacement: adım 6, 2 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement: adım 6, 2 resimden 2.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro RAM Replacement, RAM: adım 7, 2 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement, RAM: adım 7, 2 resimden 2.
    • When you open the back cover, the RAM will be located as shown in the picture.
  8. MSI GE72 6QF Apache Pro RAM Replacement: adım 8, 3 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement: adım 8, 3 resimden 2. MSI GE72 6QF Apache Pro RAM Replacement: adım 8, 3 resimden 3.
    • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
    • Carefully, slide it out at a 45 degree angle.
    • Don't press on the hinges too hard.
    • Be careful about the angle at which you're sliding out the chip.
  9. MSI GE72 6QF Apache Pro RAM Replacement: adım 9, 3 resimden 1. MSI GE72 6QF Apache Pro RAM Replacement: adım 9, 3 resimden 2. MSI GE72 6QF Apache Pro RAM Replacement: adım 9, 3 resimden 3.
    • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
    • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tanmay Kumar
461 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G4
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
nojus.zibikas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 5,125
