Ana içeriğe geç
MSI GE72 6QF Apache Pro SSD Replacement
Neye ihtiyacın var
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: adım 1, 2 resimden 1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: adım 2, 1 resimden 1.
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: adım 4, 2 resimden 1. MSI GE72 6QF Apache Pro SSD Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: adım 5, 2 resimden 1. MSI GE72 6QF Apache Pro SSD Replacement: adım 5, 2 resimden 2.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: adım 6, 2 resimden 1. MSI GE72 6QF Apache Pro SSD Replacement: adım 6, 2 resimden 2.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: adım 7, 2 resimden 1. MSI GE72 6QF Apache Pro SSD Replacement, SSD: adım 7, 2 resimden 2.
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  8. MSI GE72 6QF Apache Pro SSD Replacement: adım 8, 2 resimden 1. MSI GE72 6QF Apache Pro SSD Replacement: adım 8, 2 resimden 2.
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tanmay Kumar
461 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G4
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 8,318
