Ana içeriğe geç
MSI GP60 2PE Leopard Fan Replacement
Neye ihtiyacın var
  1. MSI GP60 2PE Leopard Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over so the back is facing up.
  2. MSI GP60 2PE Leopard Fan Replacement: adım 2, 2 resimden 1. MSI GP60 2PE Leopard Fan Replacement: adım 2, 2 resimden 2.
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  3. MSI GP60 2PE Leopard Fan Replacement: adım 3, 2 resimden 1. MSI GP60 2PE Leopard Fan Replacement: adım 3, 2 resimden 2.
    • Once all four screws are removed, lift the back off.
  4. MSI GP60 2PE Leopard Fan Replacement, Fan: adım 4, 2 resimden 1. MSI GP60 2PE Leopard Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Remove the three 5 mm screws from the fan with a Phillips #00 screwdriver.
  5. MSI GP60 2PE Leopard Fan Replacement: adım 5, 3 resimden 1. MSI GP60 2PE Leopard Fan Replacement: adım 5, 3 resimden 2. MSI GP60 2PE Leopard Fan Replacement: adım 5, 3 resimden 3.
    • Pull the wire on the bottom left of the fan out of the socket.
    • Pull the wire gently; pulling too hard could damage the wire.
  6. MSI GP60 2PE Leopard Fan Replacement: adım 6, 2 resimden 1. MSI GP60 2PE Leopard Fan Replacement: adım 6, 2 resimden 2.
    • Remove the fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,652
