Ana içeriğe geç
MSI GP60 2PE Leopard RAM Replacement
Neye ihtiyacın var
  1. MSI GP60 2PE Leopard RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard RAM Replacement: adım 2, 1 resimden 1.
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard RAM Replacement: adım 3, 3 resimden 1. MSI GP60 2PE Leopard RAM Replacement: adım 3, 3 resimden 2. MSI GP60 2PE Leopard RAM Replacement: adım 3, 3 resimden 3.
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard RAM Replacement: adım 4, 3 resimden 1. MSI GP60 2PE Leopard RAM Replacement: adım 4, 3 resimden 2. MSI GP60 2PE Leopard RAM Replacement: adım 4, 3 resimden 3.
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard RAM Replacement, Back Panel: adım 5, 1 resimden 1.
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard RAM Replacement: adım 6, 2 resimden 1. MSI GP60 2PE Leopard RAM Replacement: adım 6, 2 resimden 2.
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard RAM Replacement: adım 7, 2 resimden 1. MSI GP60 2PE Leopard RAM Replacement: adım 7, 2 resimden 2.
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard RAM Replacement, RAM: adım 8, 1 resimden 1.
    • Press the tabs on the side of the RAM to remove it.
  9. MSI GP60 2PE Leopard RAM Replacement: adım 9, 1 resimden 1.
    • Slide the RAM out of the slot carefully.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,261
