Ana içeriğe geç
MSI GP60 2pe Leopard Back Panel Replacement
Neye ihtiyacın var
  1. MSI GP60 2pe Leopard Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over so the back is facing up.
  2. MSI GP60 2pe Leopard Back Panel Replacement: adım 2, 2 resimden 1. MSI GP60 2pe Leopard Back Panel Replacement: adım 2, 2 resimden 2.
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  3. MSI GP60 2pe Leopard Back Panel Replacement: adım 3, 2 resimden 1. MSI GP60 2pe Leopard Back Panel Replacement: adım 3, 2 resimden 2.
    • Once all four screws are removed, lift the back off.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,206
