Ana içeriğe geç
MSI GP62MVR 6RF Leopard Pro Fans Replacement
Neye ihtiyacın var
  1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: adım 1, 2 resimden 1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 2, 2 resimden 1. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 2, 2 resimden 2.
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 3, 1 resimden 1.
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: adım 4, 2 resimden 1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: adım 4, 2 resimden 2.
    • Remove the eight 4.5 mm screws that hold the heat sink to the motherboard with a Phillips #0 screwdriver.
    • Remove the four 4.5 mm screws holding the fan in place also using a Phillips #0 screwdriver.
    • Watch for the screw hidden under the wires highlighted in the second picture.
  5. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 5, 2 resimden 1. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 5, 2 resimden 2.
    • Disconnect both power cables for the fans.
    • Make sure to pinch the power cables. It may require a bit of force.
  6. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 6, 3 resimden 1. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 6, 3 resimden 2. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 6, 3 resimden 3.
    • Using the Jimmy tool, remove the adhesive pads securing the fans to the board.
  7. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 7, 1 resimden 1.
    • Remove the black adhesive.
  8. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 8, 1 resimden 1.
    • Separate the heat sink from the tab on the side holding the fan in place.
  9. MSI GP62MVR 6RF Leopard Pro Fans Replacement: adım 9, 1 resimden 1.
    • Remove the three 3.5 mm screws on each fan holding the fan to the heat sink using a Phillips #0 screwdriver.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 1,251
